Tool Question
Tool Question
Post by Seadog » Sat Mar 18, 2017 8:29 am
Which do you prefer, a compression tester or a leak-down tester? It seems to me that the leak-down would tell you more from the start. Any thoughts?
Re: Tool Question
Post by LOUD MOUSE » Sat Mar 18, 2017 9:17 am
WIth a 4 stroke I want a Compression Tester.
WIth a 2 stroke I want a Leak Down Tester. .....................lm
Seadog wrote:Which do you prefer, a compression tester or a leak-down tester? It seems to me that the leak-down would tell you more from the start. Any thoughts?
cknight
Post by cknight » Sat Mar 18, 2017 9:18 am
They each have their own purposes. The compression tester will help indicate if the valves are adjusted properly, if the cam is timed correctly, and if the compression ratio is proper. Have the throttle wide open when testing. The leakdown tester will show how much cylinder and valve leakage you have, and will provide an indication of where the issues are. Regards, Chase
Post by Seadog » Fri Mar 24, 2017 8:16 am
Thanks LM and Chase. I guess I'll have to do some more thinking about which will serve me best.
hotdog09
Post by hotdog09 » Thu Apr 20, 2017 11:57 pm
How to test it?
