Warming up
Billiam
Warming up
Post by Billiam » Wed Feb 15, 2017 3:54 am
Just wondering why. I saw somewhere to allow four minutes for the engine to warmup before riding and I've seen that they do need some time on utube. When I started mine a few days ago to freshen up the battery it was pretty cold (4c !). It was at least ten minutes before she would run clean with the choke fully open.
Hence my question. Could it be down to the carb insulators or what.
Just wondering.
cb77
jkv357
Re: Warming up
Post by jkv357 » Wed Feb 15, 2017 10:00 am
Billiam wrote:Just wondering why. I saw somewhere to allow four minutes for the engine to warmup before riding and I've seen that they do need some time on utube. When I started mine a few days ago to freshen up the battery it was pretty cold (4c !). It was at least ten minutes before she would run clean with the choke fully open.
Just wondering.
cb77
Did you ride it? If not - don't start it up.
If you feel the battery is low, charge it. Starting an engine contaminates the oil, and it takes time running at operating temp to burn off the contaminants that were deposited. Starting and running for short periods only adds unburned gas and acids to the oil.
Best thing to do before storing is to change the oil and filter, then run the engine for 30 seconds to circulate the fresh oil, then don't start it again until you are ready to ride. The fresh oil will protect the internals from corrosion while sitting. Synthetic oils have advantages during storage, so use them if you can.
Billiam
Post by Billiam » Thu Feb 16, 2017 10:42 am
Interesting. No I didn't ride it. It's something I've done since forever but I always keep them running till they are nice and warm. As you say, all that condensation and stuff, needs to be burnt off.
Regards.
jkv357
Post by jkv357 » Thu Feb 16, 2017 11:56 am
Billiam wrote:Interesting. No I didn't ride it. It's something I've done since forever but I always keep them running till they are nice and warm. As you say, all that condensation and stuff, needs to be burnt off.
Regards.
It's the oil temp that's the issue. It needs to get up to operating temp (212F) and sit there for a while in order to burn-off condensation and get rid of the unburned fuel that has accumulated from the start-up. The longer the choke is on the more unburned fuel will be in the oil.
Kicking (or cranking) the engine over during the storage is a better idea, and will circulate the clean oil without the added contaminants from actual running. I've done this, with the valve cover off, on one my bikes that was being stored and was surprised at the amount of oil that was circulated to the top end just from turning over using the kickstarter.
SMBH
Post by SMBH » Thu Feb 16, 2017 6:47 pm
Take out the plugs just pop it into high gear and push it up and down your drive way the neighbours will think you are mad and only if you are a fit person we do not want to loose any of our customer with heart attacks.
I suppose one could take out the plugs and press the starter to turn over the engine then give the battery a good charge you would be doing two good things there, do put the plugs back in.
Me I just turn over the engine during storage using the kickstarter.
Billiam
Post by Billiam » Sun Feb 19, 2017 12:04 pm
the neighbours will think you are mad".
No problem there. They think I am already.
jkv357
Post by jkv357 » Mon Feb 20, 2017 3:00 pm
A recent article about engine warm-up in cold temps -
http://www.popularmechanics.com/cars/a1 ... ms-engine/
Even with an engine that has carbs, it's still not necessary to allow the engine to be "warm" before riding as long as it operates safely and will idle without choke.
