                    speedo question
speedo question
My cable works fine. But how can you replace the outside vinyl that is coming off?Mike
Re: speedo question
Buy a new cable!. ........................lm
						choctaw wrote:My cable works fine. But how can you replace the outside vinyl that is coming off?Mike
Speedo covering
I found some gray heat shrink on eBay but, it took a while.  I have not ended up using it because LM is right that a new cable is probably a better way to go.  Still, I have that gray heat shrink for that day when I can't find a new cable.
				Maximum Carnage
Cable Replacement
Anyone have a good source to buy a set of cables?
I found this on flea.bay
http://www.ebay.com/itm/152001553463?_t ... EBIDX%3AIT
Re: Cable Replacement
http://www.honda305.com/forums/where-to ... 36113.htmlMaximum Carnage wrote:Anyone have a good source to buy a set of cables?
I've gotten my cables at Scrambler Cycle
