Frame bracket/clip
Woodsie
Frame bracket/clip
Post by Woodsie » Sun Apr 12, 2015 10:47 pm
On my 66 CA78 frame up by the steering head on the left side, there is bracket/clip by a hole in the frame that the throttle cable and wiring loom come through. What is the bracket designed to support.
Hamamatsu Nippon
Post by Hamamatsu Nippon » Mon Apr 13, 2015 12:24 pm
The bracket secures the harness and the throttle cable. Run the cable at the bottom of the bracket and send it through the second hole in the frame. Run the harness above the cable and send it through the first hole.
1967 CA78
1965 CM90
Soichiro Honda
Woodsie
Post by Woodsie » Mon Apr 13, 2015 4:47 pm
Thank you. I have to re route my throttle cable which is thru the first hole.
