CL77 Headlight question
Snakeoil
Post by Snakeoil » Thu Sep 20, 2012 3:51 pm
I did a search and found no threads on this topic. I lost one beam on my original sealed headlight and took at look at the Honda parts and see that replacements, if available are priced like solid gold. Need to check other sources, but thought I'd ask if anyone has found either a decent replacement headlight or a way to modify a dead headlight to accept replacement bulbs?
I thought about carefully removing the lens from the housing so I can clean it and then maybe attach a modern removable socket to the housing with something like 3M 5200. Gotta get the lens off to remove the original bulb.
The other choice is figure out a way to attach a modern 5-1/2 inch headlight to the CL77 headlight bezel. I don't ride at night as a rule so just need two beams for passing inspection.
Any experience, thoughts, suggestions?
Thanks,
Rob
Goodysnap
Post by Goodysnap » Thu Sep 20, 2012 7:24 pm
Hello Rob,
http://www.classichondarestoration.com/ ... d_169.html
Assuming the CB and Cl are the same.
I did manage to fit a H4 capsule into an old burnt out sealed beam. I JB'd it in though so it's really only a one time use. Still running it though, 2 yrs now.
Goody
64' CB77
65' CB160
Snakeoil
Post by Snakeoil » Fri Sep 21, 2012 8:00 am
Thanks Goody. I'm getting packed for the Motogiro this weekend so I'll check out that site.
regards,
Rob
conbs
Headlight replacement
Post by conbs » Fri Sep 21, 2012 10:41 am
Snake,
I found H4 size LED headlight capsules on ebay for pretty cheap. I bought a couple but haven't tried one yet. They are supposed to be as bright as your original sealed beam. Especially for inspection purposes I would think they should work great.
Snakeoil
Post by Snakeoil » Wed Oct 03, 2012 9:15 am
Sorry for the late reply. I have an H4 headlight that has been in my parts cabinet for over 20 years. It will fit, but lacks the propery mounting tabs for the Honda bezel. I'm also a bit concerned that the wattage may be higher than the original. Although the giro is long over, I'm on a business trip now and have not gone near the bike since I returned.
I suspect for $20 I'll just buy one of those replacements.
Thanks,
Rob
cron
