Dream speedometer gear
Eljeef
Post by Eljeef » Wed Jul 28, 2010 9:28 pm
Not sure where to put this question. On the speedometer box there is a gasket. Mine has fallen apart. I can't find a reference to it in the Silver manual to get a part number. Has anyone had to deal with this? What did you do to remedy this problem? Thanks, Jeff H.
1964-C77 305 Dream
2002 BMW R1150GS
jensen
Post by jensen » Thu Jul 29, 2010 12:05 am
the oil seal ?
joeweir1
Post by joeweir1 » Thu Jul 29, 2010 3:54 pm
Posted: Fri Jul 09, 2010 10:27 am Post subject: use caulk
Thats what rebuilders use, either white marine silicone or sikeflex, just make sure you mask the glass and remove the masking right away to get a really clean line
brewsky
Post by brewsky » Thu Jul 29, 2010 4:21 pm
If you mean the one between the trim ring and the headlight housing, I just cut one out of an old inner tube.
Eljeef
Post by Eljeef » Thu Jul 29, 2010 4:56 pm
Sorry, I didn't make that clear enough. I'm talking about the other end of the speedo cable down at the front wheel. As I took my tire and rim off, the gasket or seal on the gear housing (referred to as the speedo gear box in the Silver's info) broke apart. This is what I am trying to figure out. I'll try to post pictures later tonight. Jeff H.
1964-C77 305 Dream
2002 BMW R1150GS
jensen
Post by jensen » Fri Jul 30, 2010 12:50 pm
there are two oil seals on the speedo gearbox, which one are you talking about ?
Post by LOUD MOUSE » Fri Jul 30, 2010 2:32 pm
"other end of the speedo cable down at the front wheel". ...................lm
jensen wrote:Hi,
