Identify dual sprocket?
rebelbob
Post by rebelbob » Wed Jul 15, 2009 7:29 pm
Anybody know why this bike has 2 rear sprockets? 1967 CL90 How does this work?http://i120.photobucket.com/albums/o165 ... 6CL90A.jpg
Post by davomoto » Wed Jul 15, 2009 7:58 pm
Bob, looks like someone raided an early trail 90 for that setup. The larger sprocket bolts to the smaller one, and the extra length of chain in the tool kit allows the chain to fit. This was the setup before the hi/low sub trans that came out in 1968.
rebelbob
extra sprocket
Post by rebelbob » Wed Jul 15, 2009 9:33 pm
Did they just install the chain links and leave the alignment from the front sprocket at an angle?
Re: extra sprocket
Post by LOUD MOUSE » Thu Jul 16, 2009 4:42 am
The large sprocket will fit over the teeth of the smaller and bolts and washers hold it in place. .......lm
rebelbob wrote:Did they just install the chain links and leave the alignment from the front sprocket at an angle?
rebelbob
sprocket
Post by rebelbob » Thu Jul 16, 2009 11:14 am
This sprocket is solid just like the outer one, it would not fit over the other one as you can tell by the pic below, here is a pic of the other side.
http://i120.photobucket.com/albums/o165 ... 0_4566.jpg
Re: sprocket
Post by LOUD MOUSE » Thu Jul 16, 2009 1:22 pm
I'd check it for mods as the I.D. book and the fiche show only a 45 tooth sprocket. ............lm
rebelbob wrote:This sprocket is solid just like the outer one, it would not fit over the other one as you can tell by the pic below, here is a pic of the other side.
bill440cars
Re: extra sprocket
Post by bill440cars » Wed Jul 22, 2009 10:01 pm
Yeah, the procedure that lm has described, was the thing to do back in the late 50's and early 60's for sure. I've seen that done lots of times. Not much telling if the setup you are showing, is well laid out. Bill
LOUD MOUSE wrote:The large sprocket will fit over the teeth of the smaller and bolts and washers hold it in place. .......lm
