Cleaning products that work ?
Nomad
Post by Nomad » Wed Mar 11, 2009 10:19 pm
Ive tried Castorol Superclean, (worked OK) S100 , some orange degreaser from the dollar store, (worked some too) tested oven cleaner on a scrap piece of aluminum ( no luck )even used the mini steamer of the wifes ,(may need to buy her another one ) the engine is pretty much grease free now but still very dull ,
I am hoping for some miracle in a can . at the auto parts store I started reading some mag cleaner bottles , Eagle One has a rough finish mag cleaner that looks interesting ,Has anyone used this product? and did it work good? it's made up of 4 different nasty acids so protection would be required and a strong hose to rinse off , It's the rough fins that I want to clean, I wish I had a ruined cylinder head so I could test this stuff. ,
I have noticed some bikes have black fins , is that frustration from not being able to clean so they get painted?
what products do you use to really clean the engine ? or the rest of the bike for that matter ? what works ? and what doesn't ? then how do you protect it after it is clean ?
Thank You (<>..<>)
1966 CA 160 engine #A160E-10069XX
Vin #10070XX
1971 CL 175 engine #CL175e 60179xx
vin # 60178xx
Spargett
Post by Spargett » Thu Mar 12, 2009 4:03 pm
In leu of painting or bead blasting (best solution), you can only get an engine to look "so" clean. I've seen a few cleaning jobs that looked pretty good with just elbow grease, but I imagine the look you're going for would be with one of the two first solutions.
Other than that, a scotchbrite pad in combination with any degreaser is what works best for me. It's more about the abrasive properties of the pad pulling off the corroded and stained aluminum.
Gunner_CAF
Post by Gunner_CAF » Thu Mar 12, 2009 9:22 pm
I used what Spargett did, lots of elbow grease. I don't think you will find that miracle can, and if you do, don't get any on ya.
I started with engine degreaser. I used the scotch bright pad, and ended up with carb cleaner and a toothbrush for the tight spaces. A abrasive wheel on a drill worked well for the fins. I used a medium wheel made of vinyl bristles.
Gunner
