I have put new wires on an old coil before. I don't think I have done it on a CA coil though so not sure any of the info below applies.
Would I suggest it? Not really but here is the info.
http://users.skynet.be/fgeers/mirrored/ ... 0Coil.html
interchagable parts from 63-CA72 to 65 CA77
roadrunner
65 ca77 dream 305
thanks i agree i'm just going to replace it
Replace coil wires
If I understand what you have, there is an epoxy dab on the coil case for each wire. If you remove the epoxy you will find little shards of bamboo holding the plug wires in. Once the bamboo is removed, the plug wires can be replaced. If you don't break them, the bamboo can be re-used and new epoxy applied.
Re: Replace coil wires
Conbs
Nice to have you back and to hear the voice of experience.
Also good to know that we have some 'engineering bamboo' in our bikes..... :-)
conbs wrote:If I understand what you have, there is an epoxy dab on the coil case for each wire. If you remove the epoxy you will find little shards of bamboo holding the plug wires in. Once the bamboo is removed, the plug wires can be replaced. If you don't break them, the bamboo can be re-used and new epoxy applied.
G,
Soichiro would have used nothing but the highest grade bamboo, don't you think?
G-Man wrote:Conbs
Conbs
Yes, indeed. I wonder if the deal was like Henry Ford's use of Model T radiator packing crate material for the floors of the Model T?
Recycled chopsticks from the works canteen perhaps?
conbs wrote:G,
G-Man wrote:Conbs
