i'm ordering mine from a linkage shop online. M8x1.25. LH threaded on one side, RH threaded on the other. They have them in every length, in 10mm increments. They're about $5.50 plus shipping.
They have just about everything you need to make any kind of linkage you want.
http://www.midwestcontrol.com
CB77 shift rods
What would be the benefit of going to heim joints instead of clevises? I assume it's smoother action since it's a ball and socket joint?cknight wrote:Midwest Control also has all types of metric heim ends, if you want to upgrade from the standard clevises. They are very customer oriented, with usually no minimum order amount. Great to deal with. Regards, Chase
Thanks for the confirmation on that.
I'm trying to wrap my brain around which bits i need. The "threaded stud" goes through the shifter in place of the peg that holds the clevis in place, correct?
You mentioned 6mm, so i'm looking for a set of threaded heim joints that have a M6 threaded stud, pretty short and trim the length, that have an M8 threading on the housing end?
I know M8 is the stock threading for the shift linkage, but if i'm replacing the clevis joints, could i go with M6 on the rod?
Or is there enough meat on the shifter to drill out the hole to 8mm?
