                    Correct seat strap mounting
buddy strap
my 1963 cb77 had a spring steel reinforcing strap  inserted into the hold down fabric  for strength? and/or form.   when i recovered my seat with the replacement cover and strap, i found using new banding strapping for the new insert to work perfect.  i also used new ss bolts and nuts to finish the job.  (now if i can just get the chrome seat trim finished i'll be all set)! - bk
						My seat on my 67 cb77 appears to be a stock seat and the strap folds under the seat and there are 2 bolts welded to the inside edges of the seat pan, but my seat flares up at the front by the tank, not flat like the picture posted above.
									67 cb77 Superhawk - newest project
78 cb750k Caferacer (sort of)
				AWILLIAMS64
my seat has the lift at the front as well. like i said i have 2 bolts into the pan but they are broken off.
									ekim wrote:My seat on my 67 cb77 appears to be a stock seat and the strap folds under the seat and there are 2 bolts welded to the inside edges of the seat pan, but my seat flares up at the front by the tank, not flat like the picture posted above.
1965 superhawk...project
The strap wraps around the bottom edge of the seat then the threads pass through a hole in the strap and you can hold it there with a flat washer, lock washer and 10mm nut. .............lm
									AWILLIAMS64 wrote:my seat has the lift at the front as well. like i said i have 2 bolts into the pan but they are broken off.
RIDE IT DON'T HIDE IT!
				AWILLIAMS64
