CB77 only
I've been gathering and saving this info for a few years, all gleaned mainly thanks to members here. I'm referring to the 1965 to 1968-registered (we have a couple in the UK) CB77s with the seven-figure frame numbers and their year-of-sale/registration; the range is vast -- 1000001 to 1056432 -- and just listed as "1965 - 1967" production.
Please feel free to add your own, known info within this topic.
1001184 - '65, ('64 harness)
1004539 - '65
1013505 - '65
1013558 - '65 harness
1013774 - '65 reg
1021946 - '65 harness
1022392 -
1025797 -
1028xxx - '66 reg
1030728 - '65 harness
1032915 - '65 harness
1035519 -
1038282 - '65 harness
1038331 -
1038335 - '65 harness
1039003 - '65 harness
1043961 - '66 harness
1049722 - '66 reg
1051538 - '66 harness, '67 reg
1053051 - '67
1055763 - '67
Model-year database, 1965>
- h305 Moderator
- jleewebb
friends bike
Hi Steve! A friend's bike has engine # CB77E-1026504...it has alloy fork lowers, tip-up seat, breather fittings/hoses under carbs with "Y" and hose to air cleaner, and crossover pipe on tank. He thinks it's a '67 per registration but I don't...
'62 CB77. "It's a rider."
- h305 Moderator
Re: friends bike
Lee! Great to see you're still here, amigo!!jleewebb wrote:Hi Steve! A friend's bike has engine # CB77E-1026504...it has alloy fork lowers, tip-up seat, breather fittings/hoses under carbs with "Y" and hose to air cleaner, and crossover pipe on tank. He thinks it's a '67 per registration but I don't...
He needs to look at the wiring harness tag, under the fuel tank; but it looks like another 'hanger-on' at the dealer, before registration. I'd wager, from the info herein, that it's a '65...
Do you guys, Stateside, get vehicles that are re-registered? We do in the UK, but a previously-registered bike/car/truck would have to receive a Vehicle Registration Mark -- registration plate/document -- from the year that it was originally registered.
In 2008 in Spain I bought a MINI Cooper. It had veen imported from Germany and was originally registered there in 2004, but was registered in Spain in 2006; thus it received a 2006 VRM and showed, in the Ficha Tecnica, that it was a 2006 car.
Britain's Driver and Vehicle Licensing Agency (DVLA) state that "it is an offence to make a vehicle appear newer (younger) than it is".
cb77 model year database
1051538 - 66 harness, registered ad a 67. Not sure if that s correct?
67' CB77
66’ CB77
65’ bomber
68’ hellcat
66’ CB77
65’ bomber
68’ hellcat
- h305 Moderator
Re: cb77 model year database
Most 105xxxxs seem likely to be '67-reg'd, it appears; but as you can see, I've only ever been fed two of them so far. Three, with yours, so thank you!Merz64cb77 wrote:1051538 - 66 harness, registered ad a 67. Not sure if that s correct?
