Motogiro East 2011 Spring Event
Post by davomoto » Wed May 11, 2011 11:10 am
Rob,
Flogging it could have caused it. I've seen other posts about adding lower end venting through the dipstick.ight be worth a try if the problem persists.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Snakeoil
Post by Snakeoil » Wed May 11, 2011 12:51 pm
If the only venting is thru the head, and from your reply, I suspect it is, I might try a couple of things up there. One is a reed type check valve to maintain a negative or zero pressure. That will help with any seals that might be getting tired. And also putting a coalescer in the line, which is little more than a piece of pot scrubber before the reed valve. Maybe just making the vent line loop upward under the tank first, with a coalescer would be sufficient to decrease the oil ejected out the vent pipe.
regards,
Rob
Post by davomoto » Wed May 11, 2011 12:57 pm
Cool Rob, let us know how it works out.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
