67 305 dream--- bolt under the clutch slot adjuster
how to put in the lock bolt under the clutch slot adjuster? I have tried and it is not threading on to anything. Any thoughts. Also how does the kick starter crank come off?
Re: 67 305 dream--- bolt under the clutch slot adjuster
1 Ya will need to remove the cover and place the part back where the bolt will contact it.
2 Remove the cover. .......................lm
Walt wrote:how to put in the lock bolt under the clutch slot adjuster? I have tried and it is not threading on to anything. Any thoughts. Also how does the kick starter crank come off?
