CB rear sprockets on a CL77
Hank Dymale
Post by Hank Dymale » Tue Nov 07, 2017 3:24 pm
Because I will only be using my scrambler on the back roads of Wisconsin, I would like to place a CB77 rear sprocket on my CL77. My CL77 has a DLS hub with the center measuring 3 1/4 inches across and 70 mm between bolt holes. I know from this forum that there are different rear sprocket sizes for the CL77. Does this apply to the Superhawks as well?
Question -- Will part # 41201-268-00 (for a 32 tooth Cb77 rear sprocket) fit my CL77 hub that I indicated above?
Thanks,
Hank
Eakofuta
Post by Eakofuta » Fri Mar 23, 2018 2:10 am
I smell a business opportunity
DJM
Rear sprocket
Post by DJM » Fri Mar 23, 2018 10:54 am
I'm pretty sure it will fit since the CB77 and late CL77 rear hubs are all but identical.
However going from the standard 37 tooth sprocket down to 32 teeth is a huge jump and you may end up with a bike that won't pull top gear at all. If you can find one I'd try for a 34 0r 35 to0th sprocket.
Part numbers for all the options of sprocket are in the back (Race Kit) section of the CB72/77 manual.
34 teeth is a standard sprocket for a late CB72 so might be easier to find, perhaps a used hand one from a breakers yard?
