hard to pull clutch
bart3
hard to pull clutch
Post by bart3 » Sun Aug 25, 2013 3:52 pm
The clutch lever on my bike is very hard to pull. It works but wears me down after ridding in the city. I'm not sure if it is the clutch, or if replacing only the cable would help? Any thoughts appreciated.
Thanks
OldStan
Post by OldStan » Mon Aug 26, 2013 1:36 pm
I had the same problem, finally the cable broke. The new cable solved the problem, but you might check your cable routing and make sure you don't have any tight turns as well.
63 CA78
bart3
Post by bart3 » Mon Aug 26, 2013 3:01 pm
OldStan wrote:I had the same problem, finally the cable broke. The new cable solved the problem, but you might check your cable routing and make sure you don't have any tight turns as well.
Thanks for the advice!
