I took the clutch side cover off to re-paint it and cause the gasket kit that came with my new pistons had one for this area included. I was supprised to see that there were two layers of a much beefier gasket on the cover when removed. Is this normal or the result of an over zealous previous owner? I know that the oil pump gets 2 but have not heard of doubling the clutch cover. also the new gasket is a lot thinner material. Has anyone used the gasket from classichondarestoration.com? Was it enough? will it cause problems?
Thanks in advance for your help.
Trans cover gaskets
gasket
Your PO may have used two gaskets to compensate for rough/uneven 40+ year old surfaces. I see no reason that would not work and should not effect performance of the side case. Your thinner gasket should be OK provided the surfaces are smooth and level. In a pinch I've even used oil resistant RTV successfully but not recommended. I would safely say that any product from classic would be acceptable for use. Hope this has helped you,,,,,,,,,,,,,,,Rusty
Two gaskets is a good way to bow the case. The trick I use is to start off by lightly countersinking the holes on the mating surfaces of the crankcases and the cover. Then I run a tap down teh threads to clean out years of old garbage.
Then I get a good file and lightly draw file both mating faces using kerosene or WD40 to keep the teeth from clogging. it only takes a few minutes to get teh faces cleaned or to identify low and high spots.
If they are bad you can use a sheet of wet and dry on a surface plate. An easy way to check for low spots is to apply a thin layer of bearing blue to one face and push the cover in place. Remove it and see where the blue has transferred.
