primary drive sprocket removal
Anyone have a sneakey trick to remove the nut securing the primary drive sprocket? I'm trying to remove the whole assembly with the clutch basket. Clymer leaves alot of minor details out of the manual...
Re: primary drive sprocket removal
Ya will see a locking washer with lots of WINGS and one should be hammered into one slot of the large nut.
Bend the wing out so ya can now using a soft chisel sort of tool and knock/hammer it counter clockwise to loosen/remove it. ............lm
scooterjunkie wrote:Anyone have a sneakey trick to remove the nut securing the primary drive sprocket? I'm trying to remove the whole assembly with the clutch basket. Clymer leaves alot of minor details out of the manual...
