ok.. bought a new cl77, this is number 2. got it running by quickly rebuilding the carbs and it runs sweet. but..
rear tire is flat so I had the chain tensioners loose. but I changed the oil and installed new plugs, so I decided to run it a bit to circulate the new oil. and forgot about the loose chain.
and low and behold.. I got the slack chain caught up between the front sprocket and the kick starter shaft.. and I mean really tight.
looks like the only way out is to remove the front sprocket and pull the whole mess out.. so I remove the two bolts and sprocket retainer..
question!!!!!!!.. does the sprocket just pull out or do you have to turn it like I did the retainer??. Its very very very tight and I dont want to break something by pulling too hard??
Yes,,it was a knuckle headed thing to do..and I will probably be a week getting this mess sorted out.
thanks for helping out a goofus.... Bill
how to remove front sprocket?
Re: how to remove front sprocket?
After you have removed the retainer the sprocket is designed to come in line out on the splines. No twist or turn. .....lm
sotxbill wrote:ok.. bought a new cl77, this is number 2. got it running by quickly rebuilding the carbs and it runs sweet. but..
