Transmission ?:Non-existentant kickstart stop
Adam Tucker
Post by Adam Tucker » Wed Apr 29, 2009 8:29 pm
This is the first 305 (67 Cl77) I have ever own and I jumped in head first restoring it. So basically I am wondering if anyone can shed some light as to why my wound kick start arm flies forward past what I would assume to be its normal resting place at the top of the kick stroke. Right now the the only thing stopping the arm from flying forward is the artificial stop of the right crank case. I have been studying the fiches and I can't seem to figure out if I missed installing the internal stop when I rebuilt the engine or what?
Thank for your help,
Adam
Post by davomoto » Thu Apr 30, 2009 2:04 pm
The " internal stop it a large bolt, on the clutch side, that stops the kicker gear. Did you correctly install the bolt? Will the kick shaft just spin and spin with the kicker cover off?
Adam Tucker
Post by Adam Tucker » Fri May 01, 2009 4:06 pm
Dave , looks like figured out my problem. Without the kick start cover the shaft does rotate indefinitely. In order for me to install the missing bolt, do I just need to remove left side case and install it or do I have to crack the upper and lower cases? Thanks
Post by LOUD MOUSE » Fri May 01, 2009 6:50 pm
Remove the case and the clutch. ...............lm
Adam Tucker wrote:Dave , looks like figured out my problem. Without the kick start cover the shaft does rotate indefinitely. In order for me to install the missing bolt, do I just need to remove left side case and install it or do I have to crack the upper and lower cases? Thanks
Adam Tucker
Post by Adam Tucker » Fri May 01, 2009 7:04 pm
Thanks, I appreciate info guys!
