no neutral with lever
splatt
Post by splatt » Sat Mar 26, 2005 11:17 am
ok, so heres my newest problem. on my 66-67 (not sure of year) 305 scrambler, when the clutch lever is pulled, i have no neutral. i pulled the case off, and cable seems to be working fine, i know there has to be some other ways of adjusting this, could anyone help me out? a little background on the bike- it was in storage for about 15 years, then ridden once, and stored again for another 4-5 years. thanks in advance. <br />markus
kustommusic
Re: no neutral with lever
Post by kustommusic » Sun Mar 27, 2005 6:03 pm
Markus, Have you tried moving the gear lever with the engine off and the ignition on (to see the neutral lamp)? If you can shift it that way then its clutch adjustment. Do you have access to a shop manual? That describes in detail the proper method for adjusting a clutch. That is better than guessing. Good luck! Steve Greer
splatt
Post by splatt » Tue Mar 29, 2005 11:12 pm
steve, thanks for the tip, i'll check and let you know.
jesse
Post by jesse » Wed Apr 27, 2005 5:15 am
most likely the clutch plates are sticking together.either from rust or gummy oil.you should pull and clean the clutch disks.
splatt
Post by splatt » Wed May 04, 2005 11:18 pm
yep, pulled it all apart and cleaned disks and plates. voila, i now have a working clutch. thanks everyone for your input, much appreciated. this has been an invaluable site in the past months!
