Clutch Adjuster/
young4vr
Clutch Adjuster/
Post by young4vr » Mon Apr 21, 2008 6:56 pm
I am having a slight issue with my clutch. I had so it seem to be engaging when I pulled the lever, but the clutch was not engaged. I took the left cover off and was wondering if I should be able to push the rod in by hand or if the adjuster needs to set a certain way when assembled. Any help would be helpful. I did have the transmission apart earlier and the disks did look ok.
Re: Clutch Adjuster/
Post by LOUD MOUSE » Mon Apr 21, 2008 7:19 pm
Bike type and engine number please. .............lm
young4vr wrote:I am having a slight issue with my clutch. I had so it seem to be engaging when I pulled the lever, but the clutch was not engaged. I took the left cover off and was wondering if I should be able to push the rod in by hand or if the adjuster needs to set a certain way when assembled. Any help would be helpful. I did have the transmission apart earlier and the disks did look ok.
joeweir1
Post by joeweir1 » Mon Apr 21, 2008 7:20 pm
Yes the adjuster can be put in wrong.
young4vr
Forgot that import info
Post by young4vr » Mon Apr 21, 2008 7:21 pm
its a 1966 CA77, it was torn apart when I got it, I have everything else ready for a test ride except for the clutch
Re: Forgot that import info
Post by LOUD MOUSE » Mon Apr 21, 2008 7:28 pm
You will find a small part which can/must be able to be pushed in. If you still have the cover off you may want to look at the disc where they come out of the slots around the main basket and see if they are loose. If they are you have the adjuster on the right side adjusted so the release rod is pushing on the pressure cover and needs to have you loosen the bolt with a 10mm wrench and turn the adjuster counter clockwise and then see if the disc are no longer movable then follow the HONDA procedure for adjusting the clutch. .........lm
young4vr wrote:its a 1966 CA77, it was torn apart when I got it, I have everything else ready for a test ride except for the clutch
