stuck clutch (won't disengage)
You said you lubed the cabel, when I first got our scrambler the clutch lever wouldn't even go all the way out. I took the lever out of the perch and clamped on one of those cable luber things on it and forced WD40 down it till it started coming out down by the case. It dripped WD40 on the floor for a day or so but clutch is sooo much easier to pull now and the lever will go all the way out as well.
