Hi Loud mouse, there is a vast improvement after renewing the clutch ajuster, am waiting for a new clutch cable, i also noticed the pushrod was bent which i will renew, when thats done i will look at the inner clutch hub and check for the retainer wires, at present chaging gears is no problem it just doesent like going into neutral, i would also like to thank Mike on his coment about ajusting the clutch properly every little bit helps, will report back later.
regards peweetwo
