LM is correct, if you are still unsure feel free to contact me, I only live a few miles away from you.
Al.
Gearbox Bearings
Thanks for the info everybody, I had stripped the gearbox to replace the 14mm bush & on re assembly I noticed that the final drive ball bearings did not move straight away when I spun the mainshaft, this made me think all was not as it should be. I considered Loctite but then
how could I ensure the bearings would locate the upper crank case collars, in the end I decided to just go with it as was working before.
Hi AlanW from the Wirral I don't know how to contact you other than through this forum.
Cheers Richard.
Cheers Richard.
gearbox bearings
Hi Richard, send me a PM via the forum and we can take it from there.
Cheers Al.
Cheers Al.
