pdphillips54 wrote:I tightened the spring inside the R/S cover so that I could align the two gears 0 marks. Once I let go, of course, the spring unwinds. On the outside of the R/S cover, I align the start shaft mark with the kick start lever mark. Now, to install the R/S cover, must I tighten the spring (pre-load), using the kick start lever, so that the inside gears have the 0 aligned (spring under tension) as I fit the R/S cover on the motor? That puts the kick start shaft/lever marks at about 12 o'clock. Thank for your help.
Kick start spring
Be sure to turn the KS shaft right to stop then do as you say. .................lm
pdphillips54
Re: Kick start spring
I know this topic is old but i have the same problem....
Is there any pictures or videos that could help me!?!
Thank you
Bert
Thank you
Bert
