Pulled off the side cover and... Uh Oh!
Post by LOUD MOUSE » Thu Nov 04, 2010 4:23 pm
No.
It goes on the shaft up to the pin then the filter goes onto the shaft and the shaft installs into the case. ....lm
Sascha wrote:Hey 48 - Haha... well played with the kitty litter. I would play that card if I had a cat!
Just so I get this straight:
so the washer (really thin) goes in between the casing that bolts back on the motor and the pin on the rod that has the pin facing 12:00?
sashcha
Sascha
Post by Sascha » Thu Nov 04, 2010 6:23 pm
I got it back on... LM was right, pin on inside, and the pin was around 5:00 point to get it to fit into place... What a job without taking the side casing off! Thanks guys... Now on to the next problem I can get myself into
Post by e3steve » Fri Nov 05, 2010 8:37 am
Sascha wrote:I got it back on... LM was right, pin on inside, and the pin was around 5:00 point to get it to fit into place... What a job without taking the side casing off! Thanks guys... Now on to the next problem I can get myself into
Mistakes beget knowledge, Sascha!
Sascha
Post by Sascha » Fri Nov 05, 2010 3:05 pm
e3steve... True! But such a pain to get things back in running order when you didnt see them pop out of place when you pull something apart! Lesson learned for sure! Thanks again guys... Huge help!
Post by e3steve » Sat Nov 06, 2010 5:45 am
I'll share one more experience-gained nugget, for now:
  • When splitting the crankcases, do NOT omit to remove the two nuts on top; when I was 16 my first CB spent its life with an oily rear tyre because I tried to, errr....., persuade the casings apart from the rear seam. And simply because, in my tiny mind, "those two nuts holding that little bracket can't possibly be holding the bottom casing in place"......!
My shoulders are broad enough to admit to former transgressions to help out others who may end up considering such numpty practices!
Snakeoil
Post by Snakeoil » Sat Nov 06, 2010 8:37 am
Numpty???
jensen
Post by jensen » Sat Nov 06, 2010 8:58 am
Yes, Steve speaks in riddles, but I always find the meaning, and at the end your English will be better ?
Scottish usage: a) Someone who (sometimes unwittingly) by speech or action demonstrates a lack of knowledge or misconception of a particular subject or situation to the amusement of others. b) A good humoured admonition, a term of endearment c) A reckless, absent minded or unwise person
or (specially for US citizens) :
A person who never has or never will have a f*ing clue what he is doing
or (for the dutch) :
An idiot.
at your service,
