Post
by sjptak » Mon Aug 09, 2010 3:06 pm
YEA!!!!
Thanks to your responses here and in past posts (especially I-man's from November of last year) my problem is no more. I took the clutch apart including the metal and fibre plates behind the retaining wires (or as the parts manual calls them, the Ring, clutch plate stopper). I laid them out in the same order I pulled them off. I used a very fine grit steel wool on both sides of the metal plates, removing any surface contamination. Then I cleaned each of the metal plates with brake cleaner, using the air compressor to dry them off and hopefully blowing off any leftover "grit" from the steel wool. I slammed it all back together, put both covers on, shifted to first gear and the wheel was locked. Pulled back the clutch lever and now the rear wheel spins with only the slightest bit of drag. Thanks to all the knowledgeable 305 riders out there, when I get it all back together, I'm going for a ride tonite!!!!
Now, the last question I have. Since I leave on the 27th for a 7 month trek without the bike, what precautions should I take before I store it? As I said earlier, I used this as a daily driver until I put it up for 2 years. I didn't expect a froze up clutch. Should I take the clutch plates out and let them sit in an oil bath while I'm gone? Should I just say screw it 'cause now I'm an expert and can take the left side down blindfolded? It almost looks like either way, I'll be taking it apart again.
What say ye, knowledgeable Knights of the Vintage Dream?
Stan
The guy who gets to ride tonite
