Years ago I had a similar problem on the lever that clamps to the shaft so I cut the top off the lever and sawed through the remaining bit so it was split all the way through and it always clamps up tight. Also used a longer bolt with a nut on it to make sure. It still works fine.
Leon. long time owner and rider.
Sloppy gear shit linkages
Toasty
It helps if you put where you're from in your profile. Those threads are M8. I have a drawer full of M8 spherical rod-end bearings. Sadly no left-hand ones....
I'm going to machine up a linkage set out of stainless for my CB77. That way I can control all of the clearances.
