305 Clutch Rebuild and History
garncarz
Post by garncarz » Mon Feb 10, 2014 12:12 pm
Ed: With the exception of the aluminum friction discs and the blue springs, I suppose, that looks like what I have. Maybe it was rebuilt incorrectly at some point in the past? I guess my questions are these, to bring it back to original state, what should be inside and how should it be configured? Thanks for all your help.
garncarz
Post by garncarz » Tue Feb 11, 2014 11:51 am
Five new OEM A-Plates available at http://www.rosenaupowersports.net/.
Post by LOUD MOUSE » Tue Feb 11, 2014 2:11 pm
The second clutch I mentioned had all the parts shown so you can compare every part against what you have.
I wasn't able to locate the parts finder for HONDA bikes. ......lm
garncarz wrote:Five new OEM A-Plates available at http://www.rosenaupowersports.net/.
garncarz
Post by garncarz » Tue Feb 11, 2014 2:20 pm
LOUD MOUSE wrote:The second clutch I mentioned had all the parts shown so you can compare every part against what you have.
Ed: Thanks. I have successfully completed my clutch scavenger hunt and believe that I have all the correct components. How are the spring wires installed on the clutch center? Where do the little clips go?
Post by LOUD MOUSE » Tue Feb 11, 2014 3:59 pm
Ed: Thanks. I have successfully completed my clutch scavenger hunt and believe that I have all the correct components. \
You will see the holes and slots at the rear area of the center hub. ..............lm
garncarz
Post by garncarz » Wed Feb 12, 2014 10:46 am
Ed: Got it. I didn't see the little holes for the the spring clips. Thanks.
Also, How much lateral end play should the gear change spindel shaft have?
Post by LOUD MOUSE » Wed Feb 12, 2014 12:39 pm
Couple of thousand in and out very little right/left.
The seal does a lot at the end.
I have the shift lever flush with the end. ...lm
garncarz wrote:Ed: Got it. I didn't see the little holes for the the spring clips. Thanks.
