neutral
marlin4622
Post by marlin4622 » Wed Nov 24, 2010 12:20 pm
haha thanks guys. i appreciate the clarification. now i just need to go home and do all this stuff.
brewsky
Post by brewsky » Fri Nov 26, 2010 7:16 pm
jensen wrote:Hi Brewsky,
If your bike is sitting for 3 months or more , it's good to kick around the oil (with the kick starter, no ignition) before you start it. Now, why is that ?
Oil, as any other fluid will flow to the lowest point, eventually, it only will take time and if the temperatures are high (summer) the oil will even faster flow to the lowest point. I only wish oil adhesion was so good that it stays attached to the surface for a long time.
Indeed, you have to do it regularly, regardless of what you use.
The cables with a grease nipple are the easiest to lubricate, just take a grease gun with light grease and start lubing.
I actually considered heating grease to it's liquid state and pouring into the funnel, but worried that it may cool too much before it reached the bottom....not for throttle cables though.
Glenardo
Post by Glenardo » Sun Nov 28, 2010 1:00 pm
After tearing both side covers off and cleaning all the crud and caked grease off the clutch and all the mechanism, I noticed that my elusive neutral was much easier to find.
But now I have a slight oil leak from the clutch pushrod seal. I guess all that gunk was also holding it together!!!
Post by e3steve » Sun Nov 28, 2010 2:22 pm
Glenardo wrote:After tearing both side covers off and cleaning all the crud and caked grease off the clutch and all the mechanism, I noticed that my elusive neutral was much easier to find.
Sh1t happens, mate. But the little seal is easily obtainable; it's an 8 x 21 x 6. One thing worth mentioning is that the pushrod can accrue a groove where it sits in the seal's lip. If it is grooved, to the extent that you can feel it with a fingernail, then it may never seal properly.
Post by davomoto » Sun Nov 28, 2010 2:32 pm
IMHO, this is the only way to luba a cable. It makes it so easy, that you actuall want to do it. It's also quite inexpensive, and most motorcycle shops stock them.
Davo
http://motionpro.com/motorcycle/partno/08-0182/
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Post by e3steve » Sun Nov 28, 2010 2:40 pm
Well, thar ya go, Davo. That's an amazingly-similar device to the bicycle-pump type we had back in the late '60s. I just might invest.
Glenardo
Post by Glenardo » Sun Nov 28, 2010 3:02 pm
The rod seems fine, shiny but not grooved. The good news is that it oiled up my chain pretty good!!
I saw one of those cable oilers at Harbor Freight for $6 the other day and didn't think much of it. I'll have to p/u one next time I'm there. http://www.harborfreight.com/cable-oiler-66640.html
