Hey Guys,
First of all let me say I am learning as I go here so any knowledge and patience is greatly appreciated. A little back story, a few years ago I bought a 1965 CA77 that was pretty rough, but it came along with a rebuilt engine. The last couple weeks I have put the engine in the bike and last night after getting home late from work wired her up.
Here is the problem I am having: When I engage the starter button it turns the engine over as you would expect but now I am seeing that it is also engaging the kickstart pedal. Anybody have any idea what is happening here. I was hoping not to have to get in the case if possible but it sounds like its grinding so I am sure I will. I also noticed that the kickstart pedal doesn't have any return, so I am hoping that this is just possibly a spring issue?
Link to video here:
https://www.flickr.com/photos/79457819@ ... ed-public/
Kickstarter Engaging when starter button pressed
Kickstart problems.
You really need to fix the return spring issue before you can diagnose any further problems.
If the kickstart moves this CAN be a sign of serious issues on the kickstart shaft / gearbox countershaft (one and the same thing) but the K/S shaft is held stationary by the return spring which is missing on your bike.
Fix this first and hopefully your other problem will disappear.
