Dream 305 clutch
froggy
Dream 305 clutch
Post by froggy » Fri Oct 31, 2014 2:36 pm
Hi all,
So i took my 1962 Dream 305 (CA77E-211680) clutch out to rebuilt it as it was slipping. It seems to take 1 clutch plate A (which I got) and 4 other plates p/n 22301-266-000 which i can't find. The closest in number matching is so far 22321-266-000.
I don't seem to find references for the parts and what it might mean for the specs (thickness, size, etc..) Any idea?
Also the "parts book" is have use a totally different reference # which I cannot find anywhere on eBay and related sites: C772204. Where does the difference of numbering come from and how do you cross-reference them?
The C772204 p/n might be a Honda only reference #. If so, why aren't they referred to that way?
Thank you
Cheers
Post by G-Man » Fri Oct 31, 2014 3:30 pm
Froggy
You have an 'old' parts book with an old numbering system. Honda changed the system to the new style in the early 60s.
Take a look here for the later numbers.
http://www.cmsnl.com/honda-ca77-dream-t ... ml#results
froggy
Post by froggy » Wed Nov 05, 2014 7:38 pm
thx Gman for the info. I had been on that website and was trying to get confirmation on my newly acquired parts list! Yeah for obsolete bran new NOS parts manuals...
Is there a good parts manual on ebay that has the correct p/n ?
thx
PS: I rebuild the clutch now. Is there a particular torque at which i should tight the bolt w/ springs holding the clutch plate in place or do you just tighten until the whole assembly starts rotating?
Also, I did order a NOS plate A but didn't put it in as i was 3.0mm thick and the one that was inside was 1.5mm. Being a noob at clutch rebuilding I was worried about doing something wrong. But maybe who ever worked on it last didn't place the correct parts in. Should I put the 3mm plate in instead?
froggy
Post by froggy » Thu Nov 06, 2014 7:43 pm
So, after putting all the friction disks and clutch plates together and closing the set with the pressure plate, I can move the plates/friction disk with my finger inside the basket assembly. Seems to have 1-2mm of play.
Is this normal, or should I replace the first plate that presently is 1.5mm thick with the other one I have that is 3mm thick. This would likely take care of the play I see.
Thank you
