I'm hoping one of the experts here can take a look at this photo and let me know if they think my primary chain looks ok. I think the chain adjuster looks like it is pushing the chain in quite a ways. Is there a more scientific way to gauge the chain wear other than by up/down play between the sprockets?
Thanks
Ryan
Primary chain wear
There is a procedure in the manual to check for wear. Based on the discussions I had last year on this subject, first, finding a replacement is next to impossible. Of all the methods tried to measure primary chain wear, the factory method is the best.
The "chain adjuster" in the engine is more of a "slack taker upper".
From what I gathered, if you chain is not rubbing on anything, you might as well use it because you won't find a stock replacement. Nobody even makes the raw chain.
There are mod kits developed by racers. There are posts here about primary chain upgrades and conversions.
regards,
Rob
regards,
Rob
