Kick start spring
Post by LOUD MOUSE » Sun Jun 05, 2016 9:04 pm
Be sure to turn the KS shaft right to stop then do as you say. .................lm
pdphillips54 wrote:I tightened the spring inside the R/S cover so that I could align the two gears 0 marks. Once I let go, of course, the spring unwinds. On the outside of the R/S cover, I align the start shaft mark with the kick start lever mark. Now, to install the R/S cover, must I tighten the spring (pre-load), using the kick start lever, so that the inside gears have the 0 aligned (spring under tension) as I fit the R/S cover on the motor? That puts the kick start shaft/lever marks at about 12 o'clock. Thank for your help.
pdphillips54
Post by pdphillips54 » Mon Jun 06, 2016 5:34 pm
Will do. Thanks.
Post by LOUD MOUSE » Mon Jun 06, 2016 5:36 pm
You are welcome. .................................lm
pdphillips54 wrote:Will do. Thanks.
Luss71
Re: Kick start spring
Post by Luss71 » Mon May 15, 2023 5:36 am
I know this topic is old but i have the same problem....
Is there any pictures or videos that could help me!?!
Thank you
Bert
