main stand stud removal
hotrodhendrix
Post by hotrodhendrix » Sun Sep 28, 2014 8:58 pm
Ca77 frame that already had the main stand removed when I got it. Starting reassembly and the frame still had the stock cross threaded stud in it when I poweder coated the frame. Seemingly even with some nice hammer beating it doesn't want to cone out. Is this threaded in somehow? Tricks? May just need more hammer beating but I don't want to make anything worse.
Thanks
James
mike1969
main stand
Post by mike1969 » Sun Sep 28, 2014 9:42 pm
Wanted to remove the center stand while still on the bike. I beat the stud to death, still wouldn't come out. I used a hacksaw blade to cut the shaft on each end till the whole stand fell out. Found out the stud is mounted in rubber. I was able to knock the stud out after cutting each end off and using a lot of penetrating oil. You may be able to use heat on it.
Post by G-Man » Mon Sep 29, 2014 1:29 am
James
You need a lot of heat, a lot of penetrating oil and a little beating.......
hotrodhendrix
Post by hotrodhendrix » Mon Sep 29, 2014 9:33 am
thank for the help guys!
