                    CL77 Right carb problem
My 1967 Cl77 will start with one kick. The only problem is that the left cylinder fires but the right side does absolutely nothing. I get lots of spark at the plug and I have rebuilt the carb twice but still nothing. I can spray ether directly into the carb and the cylinder roars to life. I have been struggling with this problem for over a year and I am ready to ride this summer.
Has anyone else had this problem or know of any solutions?
Thanks for help.
Thanks for help.
Thanks Davemoto,
I took the bowl off and only had a slight amount of fuel sloshing around at the bottom. Shouldn't this bowl be somewhat full of fuel? I also blew air through the fuel inlet and a few other places. Is there any way to soak the carb and dissolve any residue that may have been picked up? How much air pressure would be recommended to force through the jets?
Thanks for the help,
John
John
				mike in idaho
CL 77 Right carb problem
No increase in the rpms when I pull just the right throttle or lift the slide. When I get home from work tonite I am going to remove the carb and try to pump as much air through it as possible to dislodge any foreign matter that might have gotten into the jets or feed areas.
John
						John
