Hey guys,
I have a 66 CB160 that won't stop stalling. I cleaned the carbs and put carb cleaner in the tank. Any suggestions? It will stall after about an hour and a half of riding.
Won't stop stalling
When it stalls, crack the gas cap on the tank and listen for a woosh. This vaccume is preventing fuel from draining to the carbs.
The fix: soak the cap in lacqure thinner overnight then blow it out with an air compressor. There is a tiny vent hole in the outer ring that gets pluged with old gas and/or rust and corrosion.
