choke
choke
Should a cold ca77 only start when you use the choke. I was reading Bill Silvers manual and he says if a bike starts without using the choke this is a sign of richness. Mine always starts without choke, so do I need to adjust? If so what do I adjust, it idles fine, 1 1/4 turn out on the fast idle, but it is fouling the plugs.
CHECK YOUR NEEDLE JET
Worn needle and needle jets are always suspects. Inspect your needle and see if you can find any numbers or brand markings. I have seen some really poor aftermarket carb parts recently and I as many forum members recommend using real kehin brass whenever possible.
Fast Fred
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
66 CL77
76 CB550FKR
76 CT90
