how to remove throttle cable from ca77 carb
kennedy759
on my 67 dream, got the cap off top of carb and cable disconnected from slide valve, but how do you get the throttle cable out of the cap? is there a retaining clip, if I pull on it it moves 1/8 inch
67 ca78 Dream
82 cb450 Nighthawk
05 kfx700
07 mule
97 vette
82 cb450 Nighthawk
05 kfx700
07 mule
97 vette
Re: how to remove throttle cable from ca77 carb
The cable should just pull out. Maybe there's some dirt or corrosion holding it. A little bit of penetrating oil or heat should get it moving.
kennedy759
yep, got it, dirt, thanks
67 ca78 Dream
82 cb450 Nighthawk
05 kfx700
07 mule
97 vette
82 cb450 Nighthawk
05 kfx700
07 mule
97 vette
You're welcome! :-)
