A while back my CB77 fuel lever snapped. I was able to score an original replacement.
I swapped in the new lever but the fuel lever cover plate that seals against the wavy washer and 4-hole rubber gasket was not putting enough pressure to get a seal, and fuel was leaking.
I ordered the rebuild kit, thinking maybe my 4-hole rubber gasket was beyond its useful life.
I used the new 4-hole gasket and I still get a leak.
It's leaking from where the fuel lever cover plate meets the face of the petcock, where it's supposed to push against the wavy metal washer and 4-hole rubber gasket.
There's no gasket between the cover plate and the petcock. Is there supposed to be?
I put everything back together exactly as before, but with a new rubber gasket. I am now stumped.
See photos below:
https://drive.google.com/open?id=1ajjn5 ... V0Qrll-dSp
https://drive.google.com/open?id=1xY8kL ... cbTRr8W4C-
