Gunson Colortune / 14mm Adapter
Dr. Frankenstein
Post by Dr. Frankenstein » Sat Aug 26, 2017 6:18 am
Does anybody have a Gunson Colortune, and does it work?
The concept looks pretty cool, and everything online is inconclusive, but after much research I pulled the trigger anyway.
I bought the 12mm one, which should fit my CA's, but I don't know if I need a 'long-reach' 12mm one for the CA's I have; any ideas?
Does anybody know the difference between a 14mm and 14mm 'taper' adapter?
I'm also hunting a 12mm into 14mm adapter for the aforementioned Colortune, if anybody has one they don't want or need.
brewsky
Post by brewsky » Sat Aug 26, 2017 6:57 am
I got one a while back, but never was able to tune successfully with it.
May dig it out and try it again on a 16 hp kohler I've been tinkering with.
I don't remember needing anything that wasn't in the kit to use it on the 305.
Will check to see what I have
revlover
Post by revlover » Tue Aug 29, 2017 3:04 pm
The taper refers to how the plug seals against the head. Our bikes use a gasket seat plug while taper seat plugs are usually found in automobile applications.
Jeabjirapa
Post by Jeabjirapa » Tue Sep 12, 2017 5:01 am
I am very glad to read the new meat. This is my knowledge.
