ericmanuel
Post
by ericmanuel » Wed Mar 09, 2016 6:39 pm
Somehow I have lost the overflow tube and fitting to the carb. I lost I mean was out riding the '64 305 and when I returned home realized I had a serious fuel leak. Determined that it was coming from where the overflow fitting once was. The tube and the fitting no where to be found.
A few questions:
1. Does anyone have a bowl they would be willing to sell to me?
2. Does anyone have a DIY solution they want to share?
Thanks
Eric
Post
by G-Man » Thu Mar 10, 2016 2:49 am
Eric
I have a spare but I'm in UK and will be away for a week or two.
Let me know if you cannot get one locally.
malcolmgb
Post
by malcolmgb » Sat Mar 12, 2016 4:12 pm
Measure the hole diameter get a short section of brass tube, probably from a model shop, and fit in, maybe use some heat on the bowl to allow easy fitting or use super glue.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
AlanW
Post
by AlanW » Sat Mar 12, 2016 5:49 pm
Don't forget the height has to be correct, it would be easier to get another float bowl.
Al.
malcolmgb
Post
by malcolmgb » Sat Mar 12, 2016 6:11 pm
Sorry my mistake then, I thought it was just the external pipe missing.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
DJM
Post
by DJM » Thu Mar 17, 2016 7:01 pm
If it is only the external pipe that is missing how come it is causing a 'serious fuel leak'
A fuel leak would need the brass pipe INSIDE the float bowl to fracture (not unknown) but if this has happened there would have been a fuel leak BEFORE the external pipe dropped off. Either way a new bowl should fix it.
ericmanuel
Post
by ericmanuel » Thu Mar 17, 2016 9:17 pm
I was such a dummy. If you make sure the float is adjusted properly it won't leak. To be honest this bike may have been without the overflow tube for sometime.
Thanks
ericmanuel
