unleaded fuel Question
choctaw
Post by choctaw » Sun Feb 14, 2016 10:47 pm
Because these bikes used leaded fuel,can you burn a valve if you dont use some sort of additive.And what do most folks do. Thanks mike
DJM
Unleaded fuel.
Post by DJM » Mon Feb 15, 2016 2:46 pm
I've been running a CL77 for around eight years and CB77 for a year, both on unleaded fuel as it's hard to find leaded fuel here in the UK
No problems with either. Early engines ran a slightly higher Comp ratio which might be more of a problem but I'm sure you'll be OK. (My CB has the 'high' comp pistons fitted.
Just keep an eye on exh. valve clearances and investigate any rapid changes.
