Here is what the bike looks like now...the fenders were chopped due to the PO riveting sheet metal to the fenders to make them look original...I removed the sheet metal.
Right now, I'm chasing down carb issues. With the choke on/closed...the bike idles around 1200. As soon as I open the choke, the idle races to about 2500. Here is a video....
https://www.youtube.com/watch?v=gwdcRm ... e=youtu.be
I slacked the throttle cable at every adjuster. I have the mixture screws set at 1 1/4 turns out. I have the idle/slide screws all the way out so the slides hit the bottom. Needle clip is in the middle/third setting.
I've shot WD40 around the insulators and there has been no change in idle.
It appears as though the PO sanded the slides. Maybe this is creating a lean condition? I had one non-sanded slide, so I installed it. No change.
Here are what my plugs look like. This is after the low and high idle cycles...and a few revs. This is not showing signs of actual riding. Both plugs are obviously wet...but the plug on the left only seems wet on the electrode, whereas the plug on the right it wet all over.
