Carb removal issue
DreamGirlHouston
Carb removal issue
Post by DreamGirlHouston » Mon Feb 17, 2014 6:54 pm
I recently became the owner of a 1965 Dream CA77 and am trying to get her running before I move towards restoration. I'm trying to clean the carb and rebuild it if needed as this was sitting in a barn for quite sometime.
I have removed the nuts on the left and right bolts and am able to get enough wiggle that I am convinced there is not hondabond or any other sealer. Enough wiggling and I can see space between the carb and the flange. But the carb just will not slide forward so I can undo the throttle cable. I'm worried that is may be a bent mounting bolt. If this is the case, how does one deal with such and issue?
Any advice is welcome.
Hahnda
Post by Hahnda » Mon Feb 17, 2014 6:56 pm
Is the tube from the carb to the air filter removed?
DreamGirlHouston
Post by DreamGirlHouston » Mon Feb 17, 2014 6:59 pm
Both the airfilter and the tube are removed.
Eljeef
Post by Eljeef » Mon Feb 17, 2014 8:47 pm
The studs are probably splayed out a little. I would put the nuts on just so they cover the tip of the studs and then take a pair of pliers or channellocks or even a small clamp and squeeze them toward each other gently as you wiggle the carb body off. Mine is like that.
1964-C77 305 Dream
2002 BMW R1150GS
DreamGirlHouston
Post by DreamGirlHouston » Mon Feb 17, 2014 10:06 pm
A friend of mine suggested doing just that. I will try it tomorrow and let you know how it works.
