Need to seal Gas tank without wielding
up100
Post by up100 » Wed Dec 04, 2013 5:10 pm
Hi
Does anyone knows any products for Sealing big hold (about 2 inch ) underneath the CA77Gas tank without wielding (because I do not have wielding machine).
Thank you
Post by G-Man » Wed Dec 04, 2013 6:43 pm
Aup
With a hole that size you may want to look at a replacement tank.
http://www.ebay.co.uk/itm/Honda-C72-CA7 ... 5d366c9e30
up100
Post by up100 » Thu Dec 05, 2013 1:56 am
G-Man wrote:Aup
Hi G
Thank so much
It is too expensive for me but , I think about it,
Any solution for repairing the gas tank without wielding
jleewebb
por-15
Post by jleewebb » Thu Dec 05, 2013 9:26 am
I seem to remember the POR-15 tank sealing kit containing a piece of fiberglass mat for repairing cracks from outside before sealing inside...assuming we're talking about a 2" crack; I don''t think anything will work for a "hole" that diameter...follow preparation directions exactly...
'62 CB77. "It's a rider."
Goodysnap
Post by Goodysnap » Thu Dec 05, 2013 10:54 am
G has given you a good solution at reasonable cost. Welding new metal would be the only quality repair for a large hole in the tank. If you do not have a welder, then outsourcing the job would be your only choice for a quality repair. It would likely cost you more than 100 for a professional to do correctly so it doesn't leak. Anything less will be a temporary repair at best and will be wasted money in the log run.
JMHO,
Goody
64' CB77
65' CB160
