Sno Bol and Pine Sol
hondadreamca77
Post by hondadreamca77 » Tue Aug 06, 2013 3:21 pm
Common cleaning products tips that worked for me.....
SNO BOL TANK DE-RUST:
While waiting for the CA77 carb rebuild kit to arrive I removed the tank and de rusted it inside with Sno Bol (Dollar General $1.99). It was pretty nasty. Drained it, used bottle Sno Bol, sloshed every ten minutes for one hour, drained again and then flushed with gas, drained, blew out with air. I had previously rattled the inside with nuts and small bolts when I first got it. I got this tip off a Kawasaki forum.....I am AMAZED at the result, the inside looks new! I am now letting the tank sit with gas in it over night to test for pin holes or leaks.
PINE SOL CARBURETOR BATH:
Took carb. all apart and soaked all pot metals 4 hours in Pine Sol......then boiled all in water .......looks GREAT! Got this tip off this forum.
Only metal parts used in above applications. Rubber/ cork items set aside. Do NOT soak carb in SNO BOL....only pine Sol. otherwise it will eat up the pot metal.
Maybe we should start a 305 Cookbook.....?
Steve
68' 305 Dream, 75' Honda 750-four, 74' Honda CL 125, 72' Honda CA 70, 80' Honda Passport, 74' Aerimachi Harley Sprint 125, 64' Yamaha 90.
Re: Sno Bol and Pine Sol
Post by LOUD MOUSE » Tue Aug 06, 2013 5:46 pm
I'm going to try the Sno Bol for sure. .......lm
hondadreamca77 wrote:Common cleaning products tips that worked for me.....
Steve
hondadreamca77
Sno Bol
Post by hondadreamca77 » Tue Aug 06, 2013 8:04 pm
Sno Bol contains hydrochloric acid which eliminates rust. It works on steel but am told it dissolves pot metal and is corrosive to chrome. I am not a chemist...
brewsky
Post by brewsky » Wed Aug 07, 2013 5:01 am
Appears to be the same as "The Works" toilet bowl cleaner for about the same price. (20% hydrochloric acid)
I use it to de-rust parts before zinc plating. Works great, but flash rust returns quickly, so you have to coat it soon after using.
hondadreamca77
Zinc Plating
Post by hondadreamca77 » Wed Aug 07, 2013 9:40 am
Brewsky,
Are you doing the Zinc plating yourself or sending out? I read this is easy to learn...
brewsky
Post by brewsky » Wed Aug 07, 2013 4:55 pm
DIY.........it's really pretty easy and there are several good threads on this forum if you do a search.
hondadreamca77
Sno Bol
Post by hondadreamca77 » Thu Aug 08, 2013 9:27 am
Read the threads...going to try zinc plating in near future.
Re: Tank -You are correct; after getting shiny clean, inside of tank did flash up with a brown coating.
