Have been working on a 305 tank that had been left for 25 years with gas in it. It had alot of rust inside and I gave it 2 doses of naval jelly / water mix, about 24 hours each time.
That took care of alot of the rust but I still had a thick layer of lacquered gas along the bottom of each side. A buddy suggested using acetone (readily available at any hardware store). Used about 1/2 quart & let it do it's magic for about an hour. Then gave it a gas rinse, and another repeat soaking with naval jelly.
The acetone got rid of about 90% of the crud, and the repeat naval jelly treatment cleaned up what had been coated over. The end result looks pretty good. Now it's coated with WD40 inside until I address my petcock issues.
* CAUTION * If you're gonna use acetone in this way be VERY careful with it. It will destroy any painted surface (lucky for me I was forwarned, have never used acetone before).
Just wanted to share this tip. Hope it helps.
Old Lacquered gas
Old lacquered gas
Thanks for the tip, Tango. I'll try that on my tank too (still got some crud & rust in it).
And I've already got a petcock rebuild kit comin with some other goodies.
Question on the petcock: How does the bottom half come off from the top? I need to rebuild it, but also replace the broken lever. I have both the shop manual & parts manual but not really helpful with this. Seems like the center piece with 2 fittings is probably threaded maybe?
Will keep researching this (before I mangle something).
Old lacquered gas
Got the petcock piece figured out. Once I scraped all the crud out I found where there is a small tab to pry up the metal disk (with propellor-type fins attached). Then I could pry up the rubber stopper fitting inside. After some clean-up here & there she's ready for the replacement pieces in the kit.
