Carb rebuild
Husker45
Carb rebuild
Post by Husker45 » Sat Dec 08, 2012 10:08 am
I have seen a lot of discussion on the quality issues of various carb rebuild kits, specifically with regards to Keyster. What should I be looking for while inspecting my carb parts? How does one know if the jet needle and jets need replacing? If not Keyster, then what? My carbs have been sitting for over 40 years. Thanks for any advice.
brewsky
Post by brewsky » Sat Dec 08, 2012 12:37 pm
Most of the time you do not need a kit, only the bowl gasket, and intake O rings on the manifold spacer.
Eyerything else usually can be cleaned and re-used.
Original jets and needles are usually better quality than the replacements anyway.
Unles the original parts are mangled or obviously worn visually, just re-use them.
Husker45
Post by Husker45 » Sat Dec 08, 2012 2:28 pm
Thanks Brewsky. I have seen posts about using vinegar to clean the carb bodies. What do you recommend for the brass parts?
brewsky
Post by brewsky » Sun Dec 09, 2012 9:31 pm
I usually soak in spray carb cleaner, berrymans carb ceaner, seafoam or the like.
